Date field conversion to date and time format in Ax2009
Dear all
I need to convert to one date field to date and time format.
I first convert to date to string format, then i convert to datetime format.
in that data field type is Date, the same data field i used so many places. so i want the conversion details, any one pl help.
i tried but, one function its worked another one not worked. details follows
variable declaration:
str SFdate,STDate;
utcdatetime DTFdate,DTTdate;
1st conversion (date field to string data type) - working fine
SFdate = date2str(FDate,123,DateDay::Digits2,DateSeparator::Slash,DateMonth::Digits2,DateSeparator::Slash,DateYear::Digits4);
STDate = date2str(TDate,123,DateDay::Digits2,DateSeparator::Slash,DateMonth::Digits2,DateSeparator::Slash,DateYear::Digits4);
2nd Conversion (string type to datetime data type) - not working
DTFdate = str2datetime(SFdate,321);
DTTdate = str2datetime(STDate,321);
Advance Thanks
Saravanan.R
If I understand you goal correctly, you can simply write:
dtfDate = DateTimeUtil::newDateTime(sfDate, 0);
Dear Martin
Thank you very much, its working fine.
Regards
Saravanan.R
