Dataport Problem
Hi All, i need to create a Dataport to import some values out of a textfile into a new table. But my Problem is, that no records are stored. I have tried so many things [xx(] I am using Version 3.60 What is my mistake? Any Ideas out there??? Thanks in advance. Regards, Frank
Pls Note: 1. Running a dataport in design mode does not import data. First save it and then run it. 2. Put INIT function at OnBeforeImport Triger and Insert on OnAfterImport Trigger. It worked…?? else give more details. Regards Gaurav
Hi Gaurav, The Design mode. Thats it!!! [:D] Sometimes it is so simple. Thanks a lot. Regards, Frank
