Dataport from NAS
Hallo. i have to synchronyze navision data with a e-commerce website. I export data with XML format, with dataports and it runs ok. i want to put it under NAS, but it runs an error. [:(][:(] is there a way to do this? or a workaround ? i work with nav 3.60. thanks to all. Mirco
See here: http://www.mbsonline.org/forum/topic.asp?TOPIC_ID=7071&SearchTerms=dataport,nas
I know its slightly off topic but the Job Schedular under Service Management manages to run dataports but this doesnt run using NAS but as a session running a schedular. You could maybe adapt this functionality to run your dataports since that may be easier than changing a dataport into a codeunit.
Look at http://www.mbsonline.org/forum/topic.asp?TOPIC_ID=11722 Just testing teletype
