This is the problem im having. I have a table which has a field (among others) type boolean, and now i want to transfor that sam field to option. But i have to keep the data. If bool variable is TRUE than i have option 1, etc. I have an idea to use dataport to export the data from begining table, then import the new table definition, than import the (exported) data. Now i need to somehow transform the data from text file to coresponding data in new table definition. I have decided to use onBeforeImportRecord trigger on the same dataport.
But i dont know how to tell him to transform the selected coma-separated piece of data in the desired field of the new table?
How can i tell the dataport that i want the (exg.) seventh comma separated piece of data to be put in the field i wish?
Is there another way of dealing with this problem?
Thanks in advance
