In order to create new DB Logging Setup in AX 2009 via Admin / Setup / Database Log menu on a domain that already has DB Logging setup I’ve been told we need to delete existing entires and use the wizard to re-create existing ones plus the additonal ones required.
This surely can’t be right ? Why can this wizard not cope with creating new entires ?
I’ve even tried importing the new entries I require directly into the DATABASELOG table using the Import wizard and it creates the new DB Logging requirements in the Setup but then when I try to carry out one of these new events (ie deletion of a record from Project Quotation Header - SalesQuotationTable) the event is not tracked in the DB Logging log table - SYSDATABASELOG.
Any ideas ?
