I am converting a multi-Company NAV2009 R2 database to 2013, well…attempting to!
I am using the MS object sets (.1 in 2009 and .2 in 2013) and have run the Transfer Data and Delete Objects actions in 2009, opened the db in 2013 and converted.
I’ve opened Page 104002 (Upgrade - New Version) and successfully connected to the database. However, when using the ‘Transfer Data’ action I am getting the following errors…
In one Company this error is shown…
1, Dimension Value ID must have a value in Dimension Set Entry: Dimension Set ID=0, Dimension Code=GROUP. It cannot be zero or empty.
In several other Companies this is shown…
2, This message is for C/AL programmers: A call to System.Data.SqlClient.SqlCommand.ExecuteNonQuery failed with this message: There is already an object named ‘pk_dim355_id’ in the database. Could not create constraint. See previous errors.
REALLY really need some help as I’m not sure what I can do to resolve this. I have a table 355 full of dimension entries, which I could delete and I’m sure this will fix the problem, but then I won’t get any dimension conversion which isn’t acceptable.
HELP!?
