Hi there all. Had a search for the below but no luck.
I am using the data migration tool to import Items however I have come across a problem that seems to loop itself.
I am importing Items including the 3 Base units of measure fields (Base/Sales/Purchase).
I am aware that Table 27 (items) links to table 5404 (Item unit of measure).
Problem is that it doesnt seem possible to import one without the other - for example the item in the 5404 (Item unit of measure) has to exist before you can import the items, But you cant create the 5404 (Item unit of measure) table with no items!!
I am missing a trick here?
Any suggestions.previous experience in this area would be greatly appreciated.
You could also import all the items, all fields. But without validating the UOM-fields. And the the UOM’s. Perhaps you have to do some checks whether the UOM’s are legal - that “Base Unit of Measure Code” do have “Qty. per Unit of Measure”=1 and that the item’s UOM’s are represented in table 5404.
I think Jacques’ method is better, and will make it so you only have valid values in the table. Personally I don’t like importing data without validating. Of course if you would also develop a process that checks the validity of the fields after importing it could be useful.
