Hi, The problem is with the Data Migration of values with using Data Ports. Navision doesn’t import the values with double quotes when importing values from a CSV file. Any provision to get the values as it is (i.e.) As it is with double quotes ?
Have you had a look at the FieldStartDelimiter and FieldEndDelimiter Dataport properties? You should be able to change them to fit the file format you have.
