Data keeps processing but the report does not show..!!
I have created report and that time the data was showing then I added request form and setrange for date, location and product group. I am not able to see anything after this. When I preview the report it just shows a gray screen and does not show any data. It generating page 1 and mouse pointer is showing processing.
I don’t understand what is the issue. What do I do. Any help would be much appreciated…!!
Thank and regards.
Can you show us what you have written new and where?
Check your code specially for conditions you have return .
Check for loops you have used.
Thank you for your quick reply.
I have removed everything from request form and just kept location filter it is working fine so far. I will now add other filters and let you know if I have any more issues.
Thanks again.
Fahim
Good to hear that you have tried and got some success.
Thank you for your support. I am able to filter with all 3 options now. I am planning to add one more filter to make it even more specific. Hope fully it will work too…:slight_smile:
Will let you know if required.
Fahim.
Welcome…
Dear Amol,
A little problem again. When I run Item Ledger Entry table I can see column name “Polyhouse Code”, however, when I try to add that into the report it does not come in the fields menu. I don’t understand this…!! I want to show Polyhouse wise consumption report.
What do I do…??
Fahim.
Is it a Dimension Code?
If yes, you will have it with Global Dimension X Code name
Thank you for quick reply. Yes, I think that is it and have added to report. However, it does not come in the end report as I have just added at the end of the last column. I guess it must be with width of the page. I will check settings and hope it works…!!
Fahim.
Hi Fahim,
Did you get an answer to your question? Did it help you? The members and moderators here on DUG use our spare time and help you for free, all we ask in return is that you spent a few seconds to let us know if we helped you solve your problem.
If any of the suggestions helped you solve your question/problem, then please click the “Verify Solution” on the answer that helped you, so that we can see that your problem is now “resolved”. Otherwise let us know how if there is something else you like to know.
Also in the future please post new questions, which are not directly related the previous question as a new question.
Have a nice day! [:)]
