Hi Developers,
Could please anyone provide code for data import from excel to ax 2009 through code only. In excel sheet i have three fields like location,transaction,money. So i ve to import this data into ax.
Pls anyone help me.
moulali.
please anyone help on this.
deepi
June 7, 2012, 8:11am
3
Harish
June 7, 2012, 11:11am
4
Hi Moulali,
Save the file as .CSV
Write small X++ program to import this file using AsciiIO class
AsciiIO was discussed many times here. Please search for them.
Hi AshNan,
Thank you very much for your help.
Hi Hrarish,
I was done the same as above you discussed. I got solution. Thanks for your answer.
Moulali
i got everyone . But date is not inserting from excel to ax through x++. i will show my code
ttsbegin;
zsl.selectForUpdate(true);
zsl.Location = cells.item(row,1).value().bstr();
zsl.Totaldepositamount = cells.item(row,3).value().boolean();
zsl.Creationdate = cells.item(row,2).value().date(); // its is not insering.
zsl.insert();
ttscommit;
Could you please give the solution.
moulali.
hi ali…
u have to give 3 here…(row,3).value…because u already inserted two records…
