when i am trying to do database digram to navision database from SQL2005 …I am getting this message …
Database diagram support objects cannot be installed because this database does not have a valid owner '. To continue , first use the Files page of the database properties dialog box or the ALTER AUTHORIZATION statement to set the database owner to a valid login , then add the database support objects
I don’t understand from the message …what i should do … Can you help me to let the database diagrm works ??
