Imagine a database having two companies A and B of different busines application in NAV. I just wrote some code in an object for company A and if i execute the same object for company B the code written for company A should not execute for company B. Is there any possibility in NAV…??
In one database these Objects are common to ALL companies.
You need 2 different DBs, each with different objects. If you will try to hardcode different logic depending on Company name, sooner or later youll be in deep trouble…
I posted a reply on Mibuso to your question. It can be done by adding parameters to the functional area setup tables and forms. If the box is checked in company A, the code executes in company A. If it’s not, then the code doesn’t.
