HI Guys
Can anyone help please, trying to apply testfield function to the Buy-From Vendor No.field ‘on validate’ to ensure there is a Department Code (alternative name for Shortcutr Dimension Code 1’) but whenever it errors it comes up with :
Microsoft Dynamics NAV Classic
You must specify Shortcut Dimension 1 Code in Purchase Header Document Type=‘Order’,No.=‘IP04457’.
OK
The error coimes up which is fine but I want it to display the caption ‘Department Code;’ instead of the real field name ‘Shortcut Dimension 1 Code’. Is there a a quick way?
