Hi guys when i make invoice to sales order i found customer no different from sales invoice header to sales invoice line
why this happen .
Ex
I make sales order so-12
NO in sales invoice header is 12
AND
Document No is 12 but sell to customer field different from sales invoice line to sales invoice header in value and not same
How to avoid this from happening and what is the problem if possible
you can see this link and you will see customer no different from sales invoice line table to sales invoice header
as this link as following(clear explain to problem)
www.mediafire.com/…/111.bmp
thanks
Is there is any customization ? Please explain whole process step by step.
Regards
Ankur
This is not usual with standard NAV… there must be some customization…
please check your oninsert trigger of tabel 37 sales line.
Anil.
Check sell to and bill to customer on customer card and sales order
I Check sell to and bill to customer on customer card and sales order and found the following data :
customer no JE-TC-002522 bill to customer empty
customer no JE-TC-002552 bill to customer empty
Are this problem i think it is not problem because all customers we created as above(as bill to customer is empty) and not make any problem.
Is somebody change it from backend ??
I think may be this somebody change it from back-end but how i know that .
and are there any cases can make sales invoice header different from sales invoice line
no there are no cases as such the sell to customer number changes from header to line…
unless some body changes back end or the posting routines customized as such…!
Anil.
It is changed from backend only …
