Hi frnds,
Why group by clauses are disabled in lookups when the field using the lookup is not empty?
I want to do a custom lookup on a field in a form. The table CTable
looks like this:
Val Spec
A alpha
A beta
A gamma
B delta
C epsilon
The look up only concerns the Val
column which is defined using an EDT with a basic relationship on it: Val == CTable.Val
The lookup obviously gives me a list like this:
A
A
A
B
C
Let’s to a group by to get rid of all the duplicated As, I thought! Something along the lines of:
QueryBuildDataSource.orderMode(OrderMode::GroupBy);
QueryBuildDataSource.addGroupByField(fieldNum(CTable, Val));
Now comes the strange behaviour I have and the actual point of my question. On an empty field, the group by is correctly executed and I get this:
A
B
C
Now let’s select “A” in the lookup, then perform the lookup again because I wanted to click on “B” instead. The group by is now disabled for unknown reasons and I get the same look up results as the first I had before.
Why is it so? How can I overcome that?
Rgds
BK
