Please advise if a custom form can be permission controlled to make it VIEW only and WRITE Only for different set of users as per need.
Basically, fields in the form are editable and I am wishing to restrict through security and permissions.
Can this be achieved through development or standard ax? Please suggest!!
Yes, it can be achieved with AX security.
What is your AX version?
Hi Kranthi…its AX 2012 R3
Pls can you advise with some more detail. Standard AX configuration on custom form or security development on custom form?
You need to create a menu item (entry point) assign to the privileges and further assigned to duties and roles depending on the requirement.
technet.microsoft.com/…/gg731787.aspx
If you feel your question is answered, then you may mark it answered by clicking “This helped me” below the helpful reply.
