i am using “CurrReport.CREATETOTALS” to calculate sum of variable “tot” so i write following code on :-
RoundLoop - OnPreDataItem():- CurrReport.CREATETOTALS(tot);
But this is not showing zero after decimal point for e.g.:-
6320.00 + 1106.40 = 7426.40 but report showing 7426.4 instead of 7426.40
Pls tell me where i am doing wrong i will be very thankfull to you.
Thanx
Check decimal places or try to stretch it more.
i already stretch it and decimal places from 2:2 to 5:5 but problem not solved.
Thanx Joe,
i know how to use round function, but i don’t know how to use it with CurrReport.CREATETOTALS function can you help me how to use it.
Thanx
can you show us the your code what you have written.
My Code:-
RoundLoop, Body (4) - OnPreSection()
tot:= SalesLine.“Minimum Order Qty.”*SalesLine.“Unit Price”;
Then i added tot variable in the section designer of RoundLoop Footer.
I did the same in classic and the result is 92.70 in the report.
Quantity =9
Unit Price= 10.30
Is it related to RTC ?
Dear Manish,
R you using CurrReport.CREATETOTALS() function to calculate sum of variable.
And i m using it in MS Navision 4.0 SP3.
Thanx
i haven’t tried this yet myself, but i know you cannot put in createtotals. so, hope this will give an expected result:
tot:= round(SalesLine.“Minimum Order Qty.”*SalesLine.“Unit Price”,0.01,’=’);
Thanx Joe,
i tried it “tot:= round(SalesLine.“Minimum Order Qty.”*SalesLine.“Unit Price”,0.01,’=’);” but problem is same.
so, it indicates that you need to check to your Currency setup. Open Currency Card, go to Rounding tab. review it …
hope it helps.
