Currform.Field.Enabled based on Condition
I have the issue with Currform.Field.Enabled property based on condition.
And my code (On Item Type OnValidate & OnAfterGetCurrRecord) is
CASE “Item Type” OF
"Item Type"::“Filter Plate”:
BEGIN
//IF “Item Type” = “Item Type”::“Filter Plate” THEN BEGIN
CurrForm.“Instrument Type”.ENABLED(FALSE);
CurrForm.Range.ENABLED(FALSE);
CurrForm.Body.ENABLED(FALSE);
CurrForm.“Process Connection”.ENABLED(FALSE);
CurrForm.Model.ENABLED(FALSE);
CurrForm.BoreDia.ENABLED(FALSE);
CurrForm.RodDia.ENABLED(FALSE);
CurrForm.“Stoke length”.ENABLED(FALSE);
CurrForm.Kwatts.ENABLED(FALSE);
CurrForm.“BOM Door Cylinder”.ENABLED(FALSE);
CurrForm.“Plate Shifter”.ENABLED(FALSE);
CurrForm.“Main Cylinder”.ENABLED(FALSE);
CurrForm.“Side Cylinder”.ENABLED(FALSE);
CurrForm.“Valves Type”.ENABLED(FALSE);
CurrForm.“Valves Category”.ENABLED(FALSE);
CurrForm.PLC.ENABLED(FALSE);
CurrForm.“OP Panel”.ENABLED(FALSE);
CurrForm.MCC.ENABLED(FALSE);
CurrForm.LCS.ENABLED(FALSE);
CurrForm.RLC.ENABLED(FALSE);
CurrForm.Gladding.ENABLED(FALSE);
CurrForm.MoC.ENABLED(FALSE);
END;
"Item Type"::“Filter Cloth”:
BEGIN
END;
"Item Type"::Cylinder:
BEGIN
CurrForm.Type.ENABLED(FALSE);
CurrForm.Tickness.ENABLED(FALSE);
CurrForm.“Discharge Type”.ENABLED(FALSE);
CurrForm.Varient.ENABLED(FALSE);
END;
"Item Type"::“Power Pack”:
BEGIN
CurrForm.Size.ENABLED(FALSE);
END;
"Item Type"::Valves:
BEGIN
CurrForm.Pressure.ENABLED(FALSE);
END;
"Item Type"::“PLC Panel”:
BEGIN
END;
"Item Type"::Frame:
BEGIN
CurrForm.Make.ENABLED(FALSE);
END;
"Item Type"::Instruments:
BEGIN
END;
END;
Its not working properly when i do enter item type or when i click on next rec view. Enabled Fields varies according to the item type
Each time I choose the rec from list to card, only when i run it again it works fine.
Is it possible to make work on all cases?
Thanks in Advance,
SS
System is not properly works because you only write the code for disable the control. So once you disable the control its not activated for next record. So you need to write the code for Enable= true also. see below bold lines…
Example
CASE “Item Type” OF
“Item Type”::“Filter Plate”:
BEGIN
“Item Type”::“Filter Cloth”:
BEGIN
CurrForm.Model.ENABLED(TRUE); —
Ya Monu, Thanks for your reply. What you said is right. But in my case Field control should be enabled & disabled based on Item type. And i have done with the task. I left the code to enable the field in each type for that particular type. Thats the issue & i solved it.
SS
