I have created and posted vendor invoice.The currency conversion is not applied to only one record in voucher transactions for other records it is working perfectly…Please see the below screenshot.
Hi Kranthi,
If I uncheck the Execute business operations in CIL Currency conversion is working correctly…if it is checked then the currency conversion is not working(as above screen shot)…Please suggest me the possibilites to solve this issue…?
Hi Kranthi,
I couldn’t able to debug in visual studio…I have added breakpoints to \Classes\PurchInvoiceJournalPost post* methods, attached the process( AX32Serv.exe)…
But I got one error while performing incremental CIL…
Will Incremental CIL error affects VS debugging…?
Could you please provide stack trace for this if possible…?
The debugger was not hitting in PurchInvoiceJournalPost post* methods and CurrencyExchangeHelper while posting invoice.
Also I have overrided the insert method of generaljournalentry and generaljournalaccountentry table and addded the breakpoints…Still the debugger is not hitting
Thanks for your reply…
Can you please confirm the following…?
I ran Full CIL with the necessary steps,So the Code in CIL should be upto date.So the currency conversion shouldn’t work in both scenarios right…?
Why it is working when the CIL is off(uncheck the Execute business operations)…?
Please suggest me on this?
If it is working in non IL scenario, then it should also work IL - considering your IL code is upto date.
Do you have customization’s around this area? Have you tried the same in a standard environment?
Have you identified the code responsible for it (or) code triggering the conversion?
