Currency Code " does not exist
I am getting the following error when trying to post a sales order - ’ Currency code " does not exist.’.
The customer is in sterling as are all the lines. There is a pre-payment invoice for the order,
Getting msg when post/ship & invoice or just post/invoice.
Any help greatly appreciated.
Agi.
Agi,
Your signature says you’re from England - so your LCY should be GBP.
That means, that the ONLY place where GBP as currency code must be entered is GL Setup / LCY code and NOWHERE ELSE, it should NOT appear even in Currencies list!
In all other possible places where CurrencyCode field appears for LCY transactions must be left BLANK.
I have the same problem, have you found a solution to this? Thank you.
Sam
The solution is in my first answer - but the original poster did not bother to “verify” it.
