Crystal Report 8.0
Hi, I have been integrating Crystal Report 8.0 into Navision. But whenever I run the report through Navision, the report can be viewed but only for a short period of time. But then, it will prompt me this error:- fin.exe - application error The instruction at “0x0046507c” referenced memory at “0x01fcc238”. The memory could not be “read”. May I know what error is this? I am seeking help on it. Thanks, Cat
ngps, First of all, what version of Navision / Attain are you running? Secondly, is it the latest executables that you are using? Try this.
Hi Connull, The Navision that I am currently using is Navision 3.60 May I know, is there a problem using Navision 3.60 with Crystal Report 8.0? Your advise is much appreciated. Thanks, Cat
What is your OS and SP. A what did you heard by integrating CR in Attain ?
Hi, The OS that I am using is Window 2000. By the way, what is SP? Well, does anybody know the code of passing parameters from Attain to Crystal Report?
ngps, sp = service pack
Hi ngps, sorry for my english. I have the same problem with Navision 3.60 and Crystal Report 8.0; have you found some solution? Thanks. Giuseppe
quote:
