I added some code to the OnAfterInput of No. on the sales order. If the item isn’t valid, it goes and looks at the cross reference table to see if it can find it there. That works great, but now I need to have it update the UOM depending on the barcode scanned.
So if I scan 0111 I want it to add 0123 with a UOM EACH
If I scan 0456 I want it to add 0123 with a UOM of CASE
Right now it is just adds it as an each. So I tried doing this but it barks about it being changed by another user. I’m sure it is because I’m trying to change the No. to the correct no. from the cross reference and update the UOM at the same time. So how could I have it update the no, and then change the UOM based on what I got back from the cross reference table. Thanks for you help.
IF (Type = Type:: Item) THEN BEGIN
IF NOT ItemTable.GET(Text) THEN BEGIN
CrossReferenceTable.SETFILTER(CrossReferenceTable.“Cross-Reference No.”, Text);
IF CrossReferenceTable.FINDFIRST THEN BEGIN
Text := CrossReferenceTable.“Item No.”;
“Unit of Measure” := CrossReferenceTable.“Unit of Measure”;
END;
END;
END;
