how to insert field in field menu, i want to add additional Global dimension in my G/L register report.
thanks
jhigs
thanks
jhigs
Hi Jhigs,
Can you explain what you mean by a “field menu”?
in a report G/L Register i want to add a " GLOBAL DIMENSIONS FIELD " i checked the field menu
and i saw 2 Global dimensions only, i want to add another Global dimensions in FIELD MENU but i don’t know how?
was that in the object designer and when you run a report and try to click on VIEW >>> FIELD MENU, you only see global dimensions? this is also an issue of mine that i need some answers. but what i am trying to add is the 6 other shortcut dimensions in the field menu list. i hope we can get some answers here. thanks everyone in advance.
was that in the object designer and when you click the design in report and try to click on VIEW >>> FIELD MENU, you only see global dimensions? this is also an issue of mine that i need some answers. but what i am trying to add is the 6 other shortcut dimensions in the field menu list. i hope we can get some answers here. thanks everyone in advance.
