Creating Reports With Grouping
Can anyone help me how to create a report with grouping and sub total below it. For example, I want to have a report that will group all items per Packing Slip number.
Jeremy
What did you try ?
did you check GroupTotalFields property of dataitem in reports?
Please read the help documents
You need to create key on table with required field and then create report using report wizard it will automatically create report for you .Afterwards you can modify accordingly to you requirement.
I am using AX 2009 in creating reports, where should I find the report wizard?
Jeremy
Kindly post your question in AX forum .You will get quick answers .
As well as henceforth kindly mention which product you are using in your post.
