Creating privillege entry point x++
i have some code creating roles by x++, now i need a way to create a list of privilege entry points by x++,
for example if i know the privilege name to which i want to add entry points like menu items display or action,
based on name and type of an entry point, how do i add entry point to a privilege by x++ in D365 FnO ?
To add entry points to a privilege in D365 FnO using X++, you can follow these steps:
  1. Identify the privilege name to which you want to add entry points.
  2. Use the appropriate X++ code to create new entry points for menu items or actions.
  3. Associate the newly created entry points with the target privilege by using the privilege’s unique identifier.
  4. Save and publish the changes to make them effective.
Please make sure to handle any exceptions or error scenarios that may arise during the process. Good luck with your implementation!
