ronnel
1
Hi Guys,
I need some help. Could you give me some idea on how to create the total fields of the G/L reports segregated by account code. Please example below.
Section Body-
Code Account Name Deb Amt Cre Amt
1001 aaaaaaa 1000
1002 bbbbbbb 1000
1001 aaaaaaa 500
1002 bbbbbbb 500
Section Footer-
Total
1001 aaaaaaa 1500
1002 bbbbbbb 1500
Total field should look like this one. Is this possible guys?
Thank you in advance.
Ronnel
Create report with G/L Entry wizard and group it by Account No.
Add G/L Entry2 dataitem before the above G/L Entry and copy the header and body fields from G/L Entry to G/L Entry2 sections.
delete G/L Entry header and body sections…
ronnel
3
Hi Mohana,
Thank you for help. In grouping by Account No. Is it in the properties of the G/L Entry2 >> GroupTotalFields?
Could I still possibly get the total amount in the footer section of yhe G/L Entry2 per Account Code?
Grouping shd be done on Second GLentry dataitem
ronnel
5
Hi Mohana,
Thank you so much. It helps a lot finish my reports.
Welcome [:D]
"Verify Solution" to post that helped you solve your problem.
