hii…
i want to create a extra column for already existing table and how can i populate that column vales in ax 2012?
please help me…
hii…
please help me…
You’ll definitely need Microsoft Dynamics AX 2012 for Developers.
New fields are usually created by dragging an extended data type to a table in AOT.
How to populate a field depends on how you want to populate it. It may be set by users, from a number sequence or by your own code.
Hi…Martin
Thanks for reply , But i am not want to create extra field , I want to create extra column for suppose i have student table in that i have studentid , Name columns I created table . after that i want to create extra column in the form.with out going to datasource.how can i do that? please reply me
Sorry, I didn’t know at all that you were talking a about a form. It will help if you’re more specific.
So you want to add an existing field to an existing grid control in a form? Again, it’s documented, e.g. in How to: Add Fields to a Details Form. You can use your favourite search engine to find the documentation.
Hii…Martin Any how Thank u so much for u r time and reply…
