hi friends,
want to create a 6 report(bills) in single A4 size page…
how to do it??
do u have any idea ???
pls help me…
thanx…
hi friends,
how to do it??
pls help me…
thanx…
pls help me
Please elaborate…
here you are problem is designing the repots or designing these reports in a single A4 size page.
if you elaborate then you can get the better solution…
While posting, please make sure your post could be easily understood by others [:)] This way you will save your time as well as readers’ time.
hi,
i want a create a report, tat shd be print in column wise like,
Rno 1 Name :Kannan Rno 3 Name :suresh
Rno 2: Name :guru
I want to create a report like this
by default its cuming like this,
Rno:1 Name :kannan
Rno2 Name : muthu
i want to create like this
Rno :1 Name : Kannan Rno:3 Name :Guru
Rno: 2 Name: ganesh Rno:4 Name:Muthu
pls help me
thanx
in designing part set the property left to AutoLeft. it is default property. then it will show the columns as per requirement.
consdier Rno 1 n name as one report RNo 2 and name as report 2
i want to print report in column wise
consuder Rno 1 n name as one report, it means you want to create a sepatate report for Rno 1 only…? like this you have to create 6 reports if you have 6 records…is it right?
or
for each Rno and name, you have to create a column?
first of all your requirement is not clear…
hi venkadesh,
i want to create my report like this,
http://dynamics-ax-live.blogspot.com/2010/05/how-to-create-column-based-report.html
the code given is not working
