The Duplicate Detection jobs are great when creating/updating records, but not so much when I run a duplicate detection job and try reviewing records to merge them from the Duplicate detection job. Has anyone figured out a way to create a report or view or flow for duplicates by table/entity?
If you just want to view a report of duplicates you can use the Deduplicater Tool within the XrmToolbox. You can export the results to Excel and this exports the record id too which then allows you to add a flag column and import that back into Dynamics so you can create a View in there as well if needed
Thanks so much, Adam! I get an error trying to connect to my database but hope to figure it out this week. I didn’t realize you could export results. Creating a view will be great! Marie
