i am new to HRMS create the Position,position hierarchy in ax 2012 X++ code.
Look at the cross references, you may find some examples in standard
\Classes\HcmPositionTransition\createHcmPosition
Tahnks Karthi,
i tried to create the position hierarchy create position it automatically position is created,form is newly created position showing.can any one explain the process?
May I know your requirement
Saadullah,
my requirement is i am going to implement HRM module
step 1:I am able to create employee master.
Step2:i need to import the organization all designation(Position)
Step3:i need to import the organization all designation(Department,Job,Position) hierarchy detials
will you able to guide me? i m workin ax2012 r3 cu10
Thanks in advance.
Use the DMF, employee and postition and position hierarchy entity.
i don’t have any idea about DMF…
How will u import the values(Ex…using excel.,etc)
Look at this examples axnmaia.wordpress.com/…/
excel,csv format
Try learning it.
