Create new Lot ID for Report as Finished journal
I am trying to use odata to create journal lines on a production order.
I can do this just fine as long as a Lot ID already exists. I need to know how to create a Lot ID so that I can use it for reporting co/by products.
Thank you in advance for any help.
Hi Drew,
This usually comes down to how the Lot IDs are set up in your system. In most cases, they are either created automatically through item tracking codes (using number series) or entered manually when posting. If you want to have the Lot ID ready before reporting co/by products, you might need to first trigger the item tracking lines or extend OData a bit so it can call that part of the process.
That’s what has worked for us in similar cases, but your setup might behave differently depending on the rules in place. Hopefully this gives you a starting point. If it doesn’t solve it, you can drop me a note at hardik.gupta@allgrowtech.com and we can look into your exact setup together.
