Hello, friends
I need to create lookup which finds finds range of values combined from 4 tables. The code succesfully works with two tables but as I add the third one it doesnt work anymore. Would be nice if you could help me on this.
public void lookup()
Query query;
QueryBuildDataSource datasourceSalesTable,datasourceSalesLine, datasourceInventDim, datasourceAll;
SysTableLookup sysTableLookup;
query = new Query();
super();
datasourceSalesLine = query.addDataSource(tableNum(EBGrainItemMapping));
datasourceAll = datasourceSalesLine.addDataSource(tableNum(SalesLine));
datasourceAll.joinMode(JoinMode::InnerJoin);
//datasourceAll.fetchMode(QueryFetchMode::One2One);
datasourceAll.relations(true);
datasourceAll.addLink(fieldnum(EBGrainItemMapping, OffbalanceItem), (fieldNum(SalesLine, ItemId)));
datasourceSalesTable = datasourceAll.addDataSource(tableNum(SalesTable));
datasourceSalesTable.joinMode(JoinMode::InnerJoin);
//datasourceSalesTable.fetchMode(QueryFetchMode::One2One);
datasourceSalesTable.relations(true);
datasourceSalesTable.addLink(fieldNum(SalesLine, SalesId), (fieldnum(SalesTable, SalesId)));
//datasourceSalesTable.addRange(fieldnum(SalesTable, CustAccount)).value(CustomerAccount.valueStr());
//datasourceSalesTable.addRange(fieldnum(SalesTable, InventSiteId)).value(InventSiteId.valueStr());
datasourceInventDim = datasourceSalesTable.addDataSource(tableNum(InventDim));
datasourceInventDim.joinMode(JoinMode::InnerJoin);
//datasourceInventDim.fetchMode(QueryFetchMode::One2One);
datasourceInventDim.relations(true);
datasourceInventDim.addLink(fieldNum(SalesTable, InventSiteId),fieldnum(InventDim, InventSiteId));
sysTableLookup = SysTableLookup::newParameters(tableNum(SalesTable), this);
sysTableLookup.parmQuery(query);
sysTableLookup.addLookupfield(fieldNum(SalesTable, SalesId));
//sysTableLookup.addLookupfield(fieldNum(SalesLine, ItemId));
//sysTableLookup.addLookupfield(fieldNum(SalesLine, Name));
//sysTableLookup.addLookupfield(fieldNum(InventDim, configId));
//sysTableLookup.addLookupfield(fieldNum(InventDim, InventBatchId));
sysTableLookup.performFormLookup();
//super();
Best regards,
Roberts
