Create customer in AX using AIF services
I am trying to create a customer in AX using AIF service using a console project.I am am able to create a customer but i am unable to create addresses for this customer. I have pasted the sample code below, any help would be really appreciated.i also want to be able to add multiple addresses for a customer.
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using CreateCustomerInAx1.CreateCustomerInAx;
namespace CreateCustomerInAx1
class createCustomerTest
static void Main(string[] args)
CustomerServiceClient client = new CustomerServiceClient();
CallContext context;
try
context = new CallContext();
context.Company = “CEU”;
context.Language = “en-us”;
CreateCustomerInAx.AxdEntity_CustTable[] custTable = new CreateCustomerInAx.AxdEntity_CustTable[1];
CreateCustomerInAx.AxdEntity_CustTable customertemp = new CreateCustomerInAx.AxdEntity_CustTable();
customertemp.AccountNum = “Test_001”;
customertemp.CustGroup = “10”;
custTable[0] = customertemp;
CreateCustomerInAx.AxdEntity_DirPartyPostalAddressView[] address = new AxdEntity_DirPartyPostalAddressView[1];
address[0].Address = “test address”;
address[0].City = “test”;
address[0].CountryRegionId = “USA”;
address[0].County = “P county”;
address[0].State = “WA”;
address[0].Street = “werwer”;
address[0].District = 12;
address[0].IsPrimary = CreateCustomerInAx.AxdExtType_LogisticsIsPrimaryAddress.Yes;
address[0].LocationId = “adfas”;
address[0].ZipCode = “1782783”;
CreateCustomerInAx.AxdEntity_DirParty_DirPartyTable[] dirParty = new AxdEntity_DirParty_DirPartyTable[1];
dirParty[0].DirPartyPostalAddressView = address;
client.create(context, custTable);
Console.WriteLine(“Customer created”);
catch (Exception ex1)
Console.WriteLine(ex1.ToString());
What exactly is the problem? Did you get any errors?
No I got no errors, but i couldnt see address created in AX for this customer, i verified the tables in the background but data is not getting populated in any of the tables.
I wanted to know if this is the right way of doing it,or should i insert in address tables explicitly.
Please advice.
Don’t you even see any warnings in System administration > Periodic > Services and Application Integration Framework > Exceptions? You usually can see validation warnings that prevented something from saving.
