Create custom filtrable field with default dimension string value
Is there a way to create a field for CustTrans form based on CustTrans.defaultdimension to display the string value of this one ?
This field must be filtrable so display method doesn’t work here and we can’t use defaultDimensionView because new standard method don’t work with it.
Thank you.
If someone have some clues to reach my development i’m aware
No one could help please i’m lost ?
This is already discussed in your thread in another forum. It’ll be better to continue there rather than starting the same discussion again from scratch.
