I want to create and post general journal through X++ in AX 2012 R3. Please help.
There are many sources over web, here is one.
blogs.msdn.microsoft.com/…/
For posting you can use LedgerJournalCheckPost class.
For posting,
ledgerJournalCheckPost = LedgerJournalCheckPost::newLedgerJournalTable(ledgerJournalTable, NoYes::Yes);
ledgerJournalCheckPost.run();
Hi Kranthi,
I wrote below code but it’s giving error - "The transactions on voucher ---- do not balance as per --/–/---- "
AxLedgerJournalTable _JournalTable;
AxLedgerJournalTrans _JournalTrans;
container _acctPattern;
container _offSetAcctPattern;
LedgerJournalTable _LedgerJournalTable;
LedgerJournalCheckPost _LedgerJournalCheckPost;
GeneralJournalAccountEntry _GeneralJournalAccountEntry;
GeneralJournalEntry _GeneralJournalEntry;
super();
if (Box::yesNo("@SYS4003612",DialogButton::Yes) == DialogButton::Yes)
_JournalTable = new AxLedgerJournalTable();
_JournalTrans = new AxLedgerJournalTrans();
select _GeneralJournalAccountEntry where _GeneralJournalAccountEntry.PaymentReference == Voided_PaymentReceipts.salesOrderId;
select _GeneralJournalEntry where _GeneralJournalEntry.RecId == _GeneralJournalAccountEntry.GeneralJournalEntry;
_JournalTable.parmJournalName(“Normal_CSC”);
_JournalTable.save();
_JournalTrans.parmJournalNum(_JournalTable.ledgerJournalTable().JournalNum);
_JournalTrans.parmTransDate(_GeneralJournalEntry.AccountingDate);
_JournalTrans.parmCurrencyCode(_GeneralJournalAccountEntry.TransactionCurrencyCode);
if (_GeneralJournalAccountEntry.AccountingCurrencyAmount > 0)
_JournalTrans.parmAmountCurDebit(_GeneralJournalAccountEntry.AccountingCurrencyAmount);
else
_JournalTrans.parmAmountCurCredit(- _GeneralJournalAccountEntry.AccountingCurrencyAmount);
_JournalTrans.parmAccountType(LedgerJournalACType::Ledger);
_JournalTrans.parmOffsetAccountType(LedgerJournalACType::Ledger);
_JournalTrans.parmLedgerDimension(DimensionDefaultingService::serviceCreateLedgerDimFromLedgerDim(_GeneralJournalAccountEntry.LedgerDimension));
_JournalTrans.save();
_LedgerJournalCheckPost = LedgerJournalCheckPost::newLedgerJournalTable(_JournalTable.ledgerJournalTable(),NoYes::Yes);
_LedgerJournalCheckPost.run();
info(strFmt("Journal No %1 ",_JournalTable.ledgerJournalTable().JournalNum));
Check if you are filling the offsetLedgerDimension?
_JournalTrans.parmOffsetLedgerDimension(DimensionDefaultingService::serviceCreateLedgerDimFromLedgerDim(_GeneralJournalAccountEntry.LedgerDimension));
is it correct way? I tried but still giving error. I am not getting what to specify?
You are filling the same value in both ledgerDimension and offsetLedgerDimension.
What you are trying to achieve with this code?
I want to post journal by using X++. Actually I want to pass journal against specific record for reversal effects through X++.
So you want to created a reversal for the journal transactions/Voucher? if so you already have a similar functionality.
In the journal lines , click functions button and load ledger transactions.
I know this. Same thing I want to process through X++.
That is also written in X++. You can use the same logic.
Ok!
Class name is “LedgerJournalGetTrans”, is it? Please confirm so that I will come to know that I am on correct track.
Hope this will help …
can you send me code details , it’s asking me login and right now I don’t have gmail login.
static void VendPaymJournalCreate(Args _args)
LedgerJournalTable jourTable;
LedgerJournalTrans jourTrans;
LedgerJournalTableData jourTableData;
LedgerJournalTransData jourTransData;
LedgerJournalStatic jourStatic;
DimensionDynamicAccount ledgerDim;
DimensionDynamicAccount offsetLedgerDim;
ledgerjournalcheckpost post ;
LedgerJournalTable tablepost;
ttsBegin;
ledgerDim = DimensionStorage::getDynamicAccount(‘V000002’,LedgerJournalACType::Vend);
offsetLedgerDim = DimensionStorage::getDynamicAccount(‘ABDI316053’,LedgerJournalACType::Bank);
jourTableData = JournalTableData::newTable(jourTable);
jourTable.JournalNum = jourTableData.nextJournalId();
jourTable.JournalType = LedgerJournalType::Payment;
jourTable.JournalName = ‘PV16’;
jourTableData.initFromJournalName(LedgerJournalName::find(jourTable.JournalName));
jourStatic = jourTableData.journalStatic();
jourTransData = jourStatic.newJournalTransData(jourTrans,jourTableData);
jourTransData.initFromJournalTable();
jourTrans.CurrencyCode = ‘AED’;
jourTrans.initValue();
jourTrans.TransDate = systemDateGet();
jourTrans.AccountType = LedgerJournalACType::Vend;
jourTrans.LedgerDimension = ledgerDim;
jourTrans.Txt = ‘Vendor payment journal demo’;
jourTrans.OffsetAccountType = LedgerJournalACType::Bank;
jourTrans.OffsetLedgerDimension = offsetLedgerDim;
jourTrans.AmountCurDebit = 1000;
jourTransData.create();
jourTable.insert();
tablepost = jourTable;
ttsCommit;
info(strFmt(“Journal ‘%1’ has been created”, jourTable.JournalNum));
//LedgerJournalTable table;
//ledgerjournalcheckpost post ;
//table = //LedgerJournalTable::find(“JB0000191”);
post = LedgerJournalCheckPost::newLedgerJournalTable(tablepost,true,true);
// post = new LedgerJournalcheckPost::newLedgerJournalTable(table,NoYes::Yes,NoYes::Yes);
post.run();
info(“Done”);
Modify it accordingly
Before that code create new class for "LedgerJournalTransData " with below code
class LedgerJournalTransData extends JournalTransData
public void create(boolean _doInsert = false,boolean _initVoucherList = true)
lastLineNum++;
journalTrans.LineNum = lastLineNum;
if (journalTableData.journalVoucherNum())
this.initVoucher(lastVoucher,false,_initVoucherList);
this.addTotal(false, false);
if (_doInsert)
journalTrans.doInsert();
else
journalTrans.insert();
lastVoucher = journalTrans.Voucher;
Here is the Simple job. Create the new class first "LedgerJournalTransData " and just copy paste the code in jobs and change accordingly …
ttsBegin;
jourTable.insert();
ttsCommit;
info(strFmt(
/*LedgerJournalTable table;
table = LedgerJournalTable::find(“JB0000191”);
post = LedgerJournalCheckPost::newLedgerJournalTable(table,true,true);
post.run();
info(“Done”);*/
Yes.
Hi Kranthi,
Thanks for your help. I have done below code -
LedgerJournalTrans _LedgerJournalTrans;
GeneralJournalAccountEntry _GeneralJournalAccountEntry, _GeneralJournalAccountEntry1;
NoYes _reverseSign;
select _GeneralJournalAccountEntry where _GeneralJournalAccountEntry.PaymentReference == ‘01417286’;
_reverseSign = NoYes::Yes;
while select _GeneralJournalAccountEntry where _GeneralJournalAccountEntry.createdTransactionId == _GeneralJournalEntry.createdTransactionId
_LedgerJournalTrans.initValue();
_LedgerJournalTrans.JournalNum = _JournalTable.ledgerJournalTable().JournalNum;
_LedgerJournalTrans.Approved = NoYes::Yes;
_LedgerJournalTrans.Approver = HcmWorker::userId2Worker(curUserId());
_LedgerJournalTrans.Invisible = NoYes::No;
_LedgerJournalTrans.Transferred = NoYes::No;
_LedgerJournalTrans.TransDate = _GeneralJournalEntry.AccountingDate;
_LedgerJournalTrans.Company = curext();
//_LedgerJournalTrans.Voucher = new JournalVoucherNum(JournalTableData::newTable(_LedgerJournalTable)).getNew(true);
_LedgerJournalTrans.parmLedgerDimension(DimensionDefaultingService::serviceCreateLedgerDimFromLedgerDim(_GeneralJournalAccountEntry.LedgerDimension));
_LedgerJournalTrans.Txt = _GeneralJournalEntry.SubledgerVoucher;
_LedgerJournalTrans.TransactionType = _GeneralJournalEntry.JournalCategory;
_LedgerJournalTrans.CurrencyCode = _GeneralJournalAccountEntry.TransactionCurrencyCode;
_LedgerJournalTrans.ExchRate = _GeneralJournalAccountEntry.getAccountingExchangeRate();
if (_GeneralJournalAccountEntry.IsCorrection)
if(_GeneralJournalAccountEntry.AccountingCurrencyAmount < 0 )
_LedgerJournalTrans.AmountCurDebit = _reverseSign ? - _GeneralJournalAccountEntry.TransactionCurrencyAmount : _GeneralJournalAccountEntry.TransactionCurrencyAmount;
else
_LedgerJournalTrans.AmountCurCredit = _reverseSign ? _GeneralJournalAccountEntry.TransactionCurrencyAmount : -_GeneralJournalAccountEntry.TransactionCurrencyAmount;
else
if(_GeneralJournalAccountEntry.AccountingCurrencyAmount < 0)
else
_LedgerJournalTrans.AmountCurDebit = _reverseSign ? -_GeneralJournalAccountEntry.TransactionCurrencyAmount : _GeneralJournalAccountEntry.TransactionCurrencyAmount;
if (_reverseSign)
_LedgerJournalTrans.Qty = -_GeneralJournalAccountEntry.Quantity;
else
_LedgerJournalTrans.Qty = _GeneralJournalAccountEntry.Quantity;
_LedgerJournalTrans.insert();
info(strFmt("Journal No %1 ",_LedgerJournalTrans.Voucher));
Above code is working fine. Problem is , it’s nor creating voucher no. How to create voucher no in lines? Please help.
