For Coverage Code: Period to work the way its expected, you also have to set the Positive Days. Is this right? Is this the way it’s supposed to work. I feel its a bug. Please let me know if someone can find something on this.
You have to set the positive day’s paramater greater than the period you defined. Ax takes the min of (period, and positive days) to make the sum of quantity in the planned order. Coverage period is used, if you want axapta to create 1 planned order for a given period. The period starts at the first need of goods, and all needs in this period are summed up. The postive day’s is the maximum of day’s there may be positive stock. Or the maximum of days, planned orders will we summed up. (available in all coverage methods)
