Guys I am this error message…in nav r2
This message is for C/AL programmers:
Could not create an instance of the OLE control or Automation server identified by
GUID={1CE9DC08-9FBC-45C6-8A7C-4FE1E208A613} 7.1:{40108C54-9352-46C9-822C-027727352F00}:Unknown Automation Server.Unknown Class.
Check that the OLE control or Automation server is correctly installed and registered.
hi Mohana,
I got the same error message above. when i using NAV 2009 SP1 version 6.00. to export to file pdf and send email by outlook 2007.
Please help me
Can you show us your code…
Hi Mohana,
Thanks for your quick reply
not the screenshot of error.
I mean code which you have written to export tp PDF and sent via OUTLOOK.
Was it working earlier?
One time previouly, it was working fine, After i reinstall PDFCreator program, it wasn’t
one time previously, it was working fine, But after i do reinstall PDFCreatror , i got this errors
May be you have upgraded your PDFcreator.
You need to reselect the automation variable in C/Al Code…
hi mohana,
what do i have to do now? and How?, please tell me details.
Are you a customer or partner?
Please contact your partner for more help.
