ERROR: Could not contact the SSO server ‘myserver’. Check that SSO is configured and that the SSO service is running on that server.
(RPC: 0x800706D9: There are no more endpoints available from the endpoint mapper.).
I am getting the above error while i configure SSO for biztalk. What is the matter i dont understand? And there is no SSO service available too although is installed on my system with windows xp pro. Although this is nothing to do with Nav-biztalk integration, but i couldnt find better community forum.
Hi, I see this is not a recent post, but I’m very interested in the solution !
I’m trying to install Biztalk 2006 on a standalone XP machine but I don’t succeed in getting SSO up & running
I got the same errors, also “The Enterprise Single Sign-On Service service terminated with the following error: Unable to read from or write to the database”.
Hello Katrien, I am facing the same issue. Could you please elaborate on the solution you have suggested above. I am a bit weak on Windows Administration. See my comments below your suggestions.
assign rights to the SSODB database for this user (using SQL Server - Management Studio → security)
You mean after the SSODB is created you have to add this user to the DB under security?
to “enable” SSO in SSO Administration (ssomanage.exe, right-click on “System”)
Where do I do this, should I go to Control Panel → System, where do I find ssomanage.exe
logon with this user to do the Biztalk configuration
