Cost accounting Vs Material Costing
Hi ,
What would be difference between Costing accounting Vs Material Costing ?
Throw some light about this .
Any updates ?
Material costing is not technically an accounting concept, materials are a cost element of cost accounting, there are other accounting principles as well, it is a bit like asking cars vs engines.
What is the context of the question?
Thanks Adam for the reply.
In AX , we have the Materila costing and costing accounting module also. I would like to know the use of the costing module ?
you hopefully understand that is a completely different question [:D]
Cost accounting is more about providing information to the management to make decisions, it is more about teh presentation and analysis of the costs. I believe the AX module was written explicitly for a requirement in the Swiss market, bought by MS and is universally not used by many.
Cost Accounting I in Microsoft Dynamics AX is an internal cost flow analysis tool that helps you achieve a deeper insight into the costs incurred by your business. With Cost Accounting I you can measure in detail the economic performance and profitability of your business operations and business units.
Cost Center Accounting
• Flexible mapping of cost accounts into cost categories
• Dimensions setup for cost accounting
• Service categories for quantities management (integrated with Production and Project)
• Flexible reporting system featuring multiple line definitions and structural hierarchies
• Integrated cost accounting journals for booking internal cost accounting transactions on cost amounts or quantities
• Flexible and versatile allocation and distribution capability, including multiple parallel calculation versions
• Specific budgeting and forecasting capability, linked to ledger budget
There are then Cost Account II, III and IV which give you additional layered functionality.
This information is taken from the module guide for AX2009, so any differences in AX2012 are not considered.
