Copy records from one table to another
Hello,
I would like to copy some records form one table to another table.
I have this code:
VendorLedgerEntry.SETFILTER(“Amount to Transfer”, ‘>0’);
IF VendorLedgerEntry.FIND(’-’) THEN
REPEAT
WITH BankTransferLine DO
BEGIN
INIT;
“Vendor No.” := VendorLedgerEntry.“Vendor No.”;
“Document No.” := VendorLedgerEntry.“Document No.”;
“Currency Code” := VendorLedgerEntry.“Currency Code”;
“Amount to Transfer” := VendorLedgerEntry.“Amount to Transfer”;
“Vendor Account No.” := VendorLedgerEntry.“Vendor Account No.”;
INSERT;
END;
UNTIL VendorLedgerEntry.NEXT = 0;
It works well, when I have only one record. The record is inserted in the target table.
But when I want to copy more than one record at the same time, I get the error message:
The Bank Transfer Line already exists. Identification fields and values: Line No.=‘12’
It seems that the program always wants to insert the record in the same line.
What is missing from my code? How to code that every record is inserted in a new line?
Thanks a lot, Frida
What is the Primary Key for BankTransferLine table?
The primary key is Line No. field. I set the AutoIncrement property to Yes.
Kindly check primary key field as you have insert those fields also whenever your inserting record in ledger tables.
What do you mean by that? I don’t insert records to the ledger table, but in my own table called Bank Transfer Line.
How should I check primary key field?
Should I add something to my code? I do not know what…
Try this code
REPEAT
BEGIN
INIT;
“Line No.” := 0; // this will trigger the auto-increment to get the next number
INSERT;
END;
Thank you so much.[:)]
Welcome [:D]
