One of my client works in NAV 2013 . They are trying to copy the data from navision and paste it in excel, only first batch of data they are able to paste but after that same old contents will paste agian again.
They are accessing the navision through citrix server.
Have not worked with Citrix for years, but remember that copy/paste from a Citrix based session is depending on the Citrix configuration. It really has nothing to do with NAV at least, so you should contact a “Citrix expert”, not a NAV expert. [emoticon:c4563cd7d5574777a71c318021cbbcc8]
That’s why I asked you how you are access the Citrix server? Through Citrix desktop or distributed application?
But if you say that you can copy and paste to and from Excel, Notepad etc., then these applications are running within the same Citrix desktop environment, not to and from Citrix and local PC?
Are you able to copy from NAV to Word or Notepad then?
