copy loop problem in nav 2018 report
I have tried to run the standard NAV purchase order report 405 in a NAV 2018 database. It falls over in the copy loop data item with this line of code
SETRANGE(Number,1,NoOfLoops); NoOfLoops evaluates to 1 in this case
This causes an ‘out of memory’ error and Nav closes
If I comment out this code and the other places where there is a similar filter set (e.g. SETRANGE(Number,1,PurchLine.COUNT in the round loop data item) then the report runs.
I have found the same problem with other (standard) reports that have similar filter lines
I have run the same report in a different client (same version of nav 2018) it runs without problem.
Any explanations most welcome!
Hello
It’s an issue with your “data” - not the report. The report was last time updated on Cumulative update 09 - and that was a year ago.
I guess your problem is that you have an order with no lines at all?
Palle
Thanks for the response. The data is fine - I have checked that carefully.
I have narrowed it down a bit further - the problem only occurs when the report tries to set a filter like ‘SETRANGE(Number,1,10)’ on the system Integer table. ‘SETRANGE(SalesLine.“Line No.”,0,100000)’ works fine where the data item SalesLine is a normal navision table.
And the reports run fine in one implementation but not in another. Which makes me think it is a configuration / sql setup / environment issue, which are not my areas of expertise.
Regards
Peter
The Integer Table is an internal NAV table so I highly doubt it. If the Report has not been changed, then it have to be data.
You could try to create a simple report with with one table - Integer, and in view and properties type 1 in min value and 10 in max value. If that report runs then it is a data issue.
Palle
It is definitely NOT a data problem. I replaced the system integer table with a normal navision table populated with integers, and then ran the same SETRANGE code on this table and it worked fine.
I also created a page looking at the system integer table and set the table view to 1…10. The same thing happened with navision running out of memory and crashing.
I don’t have this problem on the other 2018 implementation, so in my mind it must be a problem outside of navision.
Regards
Peter
Could you check if the build no. of the two implementations are the same. And give me the Build No. of the faulty one, then I can chech with HQ if they have seen such an error before in that build.
Palle
Thanks for persisting with this.
Both are using 11.0.23019.0 which I believe is CU7. I looked at the date stamp on the finsql.exe file and in the one that works it is 18/07/18 and for the one that doesn’t work it is 28/06/18. Not certain how this discrepancy occurred as they were both installed from the same ‘DVD’. I didn’t do the installations so can’t explain this discrepancy.
Regards
Peter
