Hello everybody
I need to copy all files from one path to another path…for example from c:\navision to c:\navision\history.
How can i do this? I can only copy one file each time…
Please help me.
Hello everybody
Please help me.
you can use XCOPY command using SHELL function.
Thanks Nuno
Can’t i use something like this:FILE.COPY?
I’m a beginner in Navision…
yes, you can also use.
f.RESET;
f.SETRANGE(Path, ‘c:’);
IF f.FIND(’-’) THEN
REPEAT
COPY(f.path + f.Name, ‘c:\navision\history’ + f.Name);
UNTIL f.NEXT = 0;
f is a Record of type File
Thank you Nuno.
It’s solved!!!
You may want to add the setting:
F.SETRANGE(“Is a file”,TRUE);
I also forget to mention that, if you have subfolders you will have problems.
Thanks Nicholas,
pardon me as i am new to NAV… where do i input the codes as indicated above?
In a Codeunit, Table, etc.
Depends a lot what you are trying to achieve.
