I experienced that the ‘Copy Document’ function on Purchase Invoice DID NOT copy the values of ‘Receipt No.’ and ‘Receipt Line No.’ fields.
I wanted to create a new Purchase Invoice from a previously entered but not-Posted Purchase Invoice where all the PRD documents were referenced properly, i.e. in every item lines ‘Receipt No.’ and ‘Receipt Line No.’ fields were filled.
I didn’t want / I was not able to post this previously entered but not-Posted Purchase Invoice because of a special reason.
Since it had hundreds of lines I didn’t want to collect again all the PRD documents by the ‘Get Receipt Lines’ function.
Since non-Posted Purchase Invoices don’t “close” the referenced PRD documents I can’t see the reason why the ‘Copy Document’ function does not take into account these information as well.
So,
Is there any Setup option by which we could change this operation of ‘Copy Document’ function ?
Or it’s a feature of Copy Document’ function and we have to find a workaround ?
Unfortunately I don’t have right to check the source code.
We are a subsidiray of a legal parent … w/o any documentation.
Could you please send me a small part of NAVI User Guide which describes the operation of ‘Copy Document’ function on ‘Purchase Invoice’ documents and in which I could see that this function “wants” to copy PRD-references as well ?
Unfortunately I received a feedback from our foreign colleagues in which they considered such operation of ‘Copy Document’ function as a feature and not a bug …
Copy document can not copy the receipt no and receipt line no to the invoice… it is always standard navision function get reciept liens which can facilitate this and allow you to post your invoices against the reciepts.
so for now to fix your history you need to consult dynamics solution provider or a programmer.
in future if you want to map invoices against receipts then always use function get receipt lines.
