Hello Everyone,
please help me to get value on period start and period end time.
i have to get value like below format.
00:00-12:59 as 00 03:00-03:59 as 03 19:00-19:59 as 19 for 24 hour time period. Thanks in advance. |
Hello Everyone,
Hi Shyam,
Can you be specific , i understood like you just need starting hour/ period which can be taken like
if your Time Format is HH-MM-SS then
TimeInText := FORMAT(Time);
then you just need Hours.
EVALUATE(Hourtime,COPYSTR(TimeInText,1,2));
OR IF you are getting like HH-MM-SS-AM.
then
Same above
IF COPYSTR(TimeInText,10,2) = ‘PM’ THEN
Hourtime += 12;//to add to your previous time as it pm eg: 6 + 12 = 18 pm
So make some additional conditions so that you achieve your Requirements ,
Let me know if helped[:D]
Dear Sir,
Thank you for the help,
Logic provided by you is working fine for me.we are copying first 2 values from time field.
But in the case of 12:00:00-12:59:59 Am i want to display 00 in place of 12.
For PM time period its perfect. so any suggestion for that?
Kindly check the below output.
12:00:00 AM-12:59:59 AM 12 >> Instead 00 Required
1:00:00 AM- 1:59:59 AM 1
3:00:00 AM- 3:59:59 AM 3
4:00:00 AM- 4:59:59 AM 4
11:00:00 AM-11:59:59 AM 11
12:00:00 PM-12:59:59 PM 12
1:00:00 PM- 1:59:59 PM 1
2:00:00 PM- 2:59:59 PM 2
5:00:00 PM- 5:59:59 PM 5
6:00:00 PM- 6:59:59 PM 6
7:00:00 PM- 7:59:59 PM 7
8:00:00 PM- 8:59:59 PM 8
9:00:00 PM- 9:59:59 PM 9
10:00:00 PM-10:59:59 PM 10
11:00:00 PM-11:59:59 PM 11
Thanks again for the help.
Hi Shyam,
I got it as 12PM is 12T , So you need 12 Am i.e 00T .So i think you definitely use/ compare for AM or PM from Above post of mine… i.e copy AM/Pm , Then why dont you compare it before taking further step as like
IF (Hourtime = 12) AND (AM_PM = 'AM) Then
Hourtime := 00T;
If it is NOT Helpful then Let me Know…[;)]
right sir…But when i am trying to assign 12 in Hourtime getting type conversion error.
can you tell me Hourtime datatype or i have to take another variable of time type.
Hi Shyam ,
Go Through This post below …[:D]
http://beginnersnav.blogspot.in/2015/12/convert-time-to-decimal-interger-as-per.html
Let me Know if you got your requirement…[;)]
Thanks sir
it works for me.
