hi
I want to convert str2enum when I do it it return error how I can do this ?
this is the code :
query query;
querybuilddatasource querybuilddatasource;
querybuildrange querybuildrange;
queryrun queryrun;
empltable empltable;
HAL_TmpChargement tmp;
super();
query = new query();
querybuilddatasource = query.addDataSource(tablenum(empltable));
querybuildrange = querybuilddatasource.addrange(fieldnum(empltable,PBAUserProfile));
querybuildrange.value(“point”);
queryrun = new queryrun(query);
while (queryrun.next())
empltable =queryrun.get(tablenum(empltable));
ttsbegin;
while select forupdate tmp
tmp.hal_pointer = str2enum(empltable.EmplId); // here its return error why ? can you correct me ?
tmp.update();
HAL_TmpChargement_ds.refreshEx();
ttscommit;
thank you
