Convert Hex to char
I want to convert the hexadecimal to character.
For instance, if you put in “3B” it would return “;” and when you put in “33” it would return “3”.
Thanks regards,
G.Rajkumar
Don’t forget that what a binary value means depends on the encoding used for interpretation.
If all what you need is ASCII, use num2char():
num2char(hex2int('3B'))
If the problem is more complex, consider using the Encoding class (and methods such as GetString()) via .NET Interop.
Dear Martin,
Just I want to know that this function will run in Ax 2009.
G.Rajkumar
Yes, it will. Try it yourself.
Thanks Martin,
I will try & come back with good news.
G.Rajkumar.
Dear Martin,
Its working fine.
G.Rajkumar
