conversion of number to the text
hi all
First I want to thank all employees of this site, as is to answer questions quickly and in a manner easy to understand
Step by step, leading to speed completion of the work
My next question : For the conversion of number to the text here is intended for the checks and the financial Fouaterowalsndhat
An example of this
1555 this is numbe
To change the number to the text
Thousand five hundred and fifty-five
I heard the file Chunk file code : Axapta‏
can any one help how we use this file which function need use and methods
to call to forms in textbox and in the reports
and if any one have this file to send me by attach or send by e_mail
pls I need in english and arabic Language
If there is anything else other than this file to Amcklp I want HapAstaa It figures to the text as if in a previous example
thank all and pls help me
check this link I hope this will help u…
http://kranthiax.blogspot.com/2010/11/changing-numeral-to-text-in-indian.html
HI Bas,
Use Global class…
Global::numeralsToTxt(1555)…
Naresh Kolli
ok i will start with it
but can u help how to call this class in feilde (Textbox) or in the coulom in the Grid in the form and in the report
thanks
thanks for
i create class like this
new class
new methods
and i write the code
static TempStr numeralsToTxt_IN(real _num)
int numOfPennies = (decround(frac(_num), 2) * 100) mod 100;
real test = _num - frac(_num);
int numOfTenths;
str 20 ones[19], tenths[9], hundreds, thousands, lakhs, crores;
int64 temp;
str 200 returntxt;
str 200 pennytxt;
int penny;
real modOperator(real a1, real a2)
int tmpi;
real tmp1, tmp2;
tmp1 = a1 / a2;
tmpi = real2int(tmp1);
tmp2 = tmpi;
return (tmp1 - tmp2)*a2;
real checkPower(real _test, int64 _power)
int64 numOfPower;
if (_test >= _power)
numOfPower = _test div _power;
if (numOfPower >= 100)
temp = numOfPower div 100;
returntxt = returntxt + ’ ’ + ones[temp] + ’ ’ + hundreds;
numOfPower = numOfPower mod 100;
if (numOfPower >= 20)
temp = numOfPower div 10;
returntxt = returntxt + ’ ’ + tenths[temp];
numOfPower = numOfPower mod 10;
if (numOfPower >= 1)
returntxt = returntxt + ’ ’ + ones[numOfPower];
switch(_power)
case 10000000 :
returntxt = returntxt + ’ ’ + Crores;
_test = modOperator(_test, 10000000);
break;
case 100000 :
returntxt = returntxt + ’ ’ + lakhs;
_test = modOperator(_test, 100000);
break;
case 1000 :
returntxt = returntxt + ’ ’ + thousands;
_test = modOperator(_test, 1000);
break;
case 100 :
returntxt = returntxt + ’ ’ + hundreds;
_test = modOperator(_test, 100);
break;
return _test;
#Define.text_1(‘One’)
#Define.text_2(‘Two’)
#Define.text_3(‘Three’)
#Define.text_4(‘Four’)
#Define.text_5(‘Five’)
#Define.text_6(‘Six’)
#Define.text_7(‘Seven’)
#Define.text_8(‘Eight’)
#Define.text_9(‘Nine’)
#Define.text_10(‘Ten’)
#Define.text_11(‘Eleven’)
#Define.text_12(‘Twelve’)
#Define.text_13(‘Thirteen’)
#Define.text_14(‘Fourteen’)
#Define.text_15(‘Fifteen’)
#Define.text_16(‘Sixteen’)
#Define.text_17(‘Seventeen’)
#Define.text_18(‘Eighteen’)
#Define.text_19(‘Nineteen’)
#Define.text_20(‘Twenty’)
#Define.text_30(‘Thirty’)
#Define.text_40(‘Forty’)
#Define.text_50(‘Fifty’)
#Define.text_60(‘Sixty’)
#Define.text_70(‘Seventy’)
#Define.text_80(‘Eighty’)
#Define.text_90(‘Ninety’)
#Define.text_100(‘Hundred’)
#Define.text_1000(‘Thousand’)
#Define.text_100000(‘Lakh’)
#Define.text_10000000(‘Crore’)
#Define.text_and(‘Rupees and’)
#Define.text_paise(‘Paise Only’)
#Define.text_ruppe(‘Rupees Only’)
ones[1] = #text_1;
ones[2] = #text_2;
ones[3] = #text_3;
ones[4] = #text_4;
ones[5] = #text_5;
ones[6] = #text_6;
ones[7] = #text_7;
ones[8] = #text_8;
ones[9] = #text_9;
ones[10] = #text_10;
ones[11] = #text_11;
ones[12] = #text_12;
ones[13] = #text_13;
ones[14] = #text_14;
ones[15] = #text_15;
ones[16] = #text_16;
ones[17] = #text_17;
ones[18] = #text_18;
ones[19] = #text_19;
tenths[1] = ‘Not used’;
tenths[2] = #text_20;
tenths[3] = #text_30;
tenths[4] = #text_40;
tenths[5] = #text_50;
tenths[6] = #text_60;
tenths[7] = #text_70;
tenths[8] = #text_80;
tenths[9] = #text_90;
hundreds = #text_100;
thousands = #text_1000;
lakhs = #text_100000;
crores = #text_10000000;
test = checkPower(test, 10000000);
test = checkPower(test, 100000);
test = checkPower(test, 1000);
test = checkPower(test, 100);
if (test >= 20)
numOfTenths = test div 10;
returntxt = returntxt + ’ ’ + tenths[numofTenths];
numOfTenths = numOfTenths mod 10;
test = test mod 10;
if (test >= 1)
numOfTenths = real2int(test);
returntxt = returntxt + ’ ’ + ones[numOfTenths];
if (numOfPennies)
if (numOfPennies >= 20)
penny = numOfPennies div 10;
pennytxt = tenths[penny];
numOfPennies = numOfPennies mod 10;
if (numOfPennies >= 1)
pennytxt = pennytxt + ’ ’ + ones[numOfPennies];
returntxt = returntxt + ’ ’ + #text_and + ’ ’ + pennytxt + ’ ’ +#text_paise;
else
returntxt = returntxt + ’ ’ + #text_ruppe;
return returntxt;
what i do is right
and what the next step
in my form i have 2 field
1- number field is int write the numbe
2- conversion_TEXT field to text (now empty )
what i want to do
whitch function and metods use when i write number field show me in conversion_TEXT text
like exampl i write number field 1555
show me in conversion_TEXT field
thanks for help
hi all
what i do is right
what i want to do
thanks for help
Mr Naresh Kumar Kolli
did u mean how have the Ax have this class Global::numeralsToTxt
and if have how i accept with textbox and colum in the grid
thanks for help
thank all
i gotted
Hi Bas,
Post the solution on how u solved it, so that it can be a future reference for all.
