Just use the location. Post the items from you stock into the location “salesX”. So you still have it in you “stock”. When the salesman is back issue the invoice by using the location “salesX”. You have everything you want.
When I use the TRANSFER ORDER for this kind of transaction…there an error msg that say Inventory is not sufficient…but i have enough inventory for t that item… why it does mean? hoping for your reply.
Are you really sure you have qty. on THAT stock (location) you want to fransfer FROM? Please check the item using Item-card - item - item availability by - location
