Hola! Is there any way to determine where exactly do i use a field for example, some sort of report available?
Hi, You can use Developers Toolkit and run the Where Used By menu.
Hi, i used for analogous purposes objects export into ‘txt’ format. It helps sometime. BR, Anthony
